I put on a
twin stick on my T Shift T case will not let me into High range any thougths?
No High 4 wheel drive have not done any internal work (mite be over my head) So I an waiting till I do my 203 to 20
Have had the twin stick in for about a year though it was time to fix. Front end will only go neutral to 4 low will not pull in to 4 high The rear works fine 4 low neural 2 high. no internal work has been done.
When you are trying to put the front into 4 Low, is the rear already in 4 Low? I beleive the rear has to go into 4 Low first, then you can shift the front into 4 Low. Then the front needs to come out of 4 Low first, then you can shift the rear out.
Low range works great I can not get it into 4 wheel high range. We are only talking about the front. I have no prolems with the back I can get 4 low / neutral / 2 high
