6Daze??? You have this set up right....see below
I have the astro van booster with the flat mounting plate and am hoping to mount it to the firewall using the stock EB brake pedal location and clear the explorer intake...we'll see. Anyone know if it will?
I grabbed the astro van master cylinder too. I have Disc/Disc with Ford big brakes front and Chevy 3/4 ton 14 bolt caliper rear, but I think the master cylinder for the astro van was Disc/Drum. I didn't grab the proportioning valve/H block or whatever it was that I saw with it and left behind. Will I need a residual valve for the rear? Should I go back and get that valve/block? Anything else?
People who have done the astro van...how's the brake pedal feel...soft...short...are you happy with it?
Is there any booster that bolts up to the stock eb brake location and clears the explorer intake?
