Well, the parts for the new 69 351W have been ordered. I got a engine kit with new pistons, 30 over, gaskets, rings, bearing, seals, freeze plugs and an oil pump. I also ordered the comp cams 4X4 extreme complete kit, with cam for rpm range 1000-5000, double roller timing chain, lifters, valve springs, locks, retainers, and seals. I'm having a friend in an engine shop in Idaho do the machine work, and assembly. He's putting new valves in also. I will be picking it up over the Thanksgiving break. When he tore it apart he found three cracked pistons, and the cam bearing wear shot. I just hope he doesn't find anything else before he is done. Man, I haven't driven the bronco since the gathering at Chuck's house. I'm going into withdrawl.
Here's a link to the guy who's building the engines bronco.
http://www.broncofix.com/viewtopic.p...ghlight=rolled
