I think my instrument cluster voltage regulator is not producing the correct voltage, everything reads low (oil reads 20psi , mechanical gauge reads 45 psi - temp reads 175F and I have a 195F thermostat). Replacement instrument voltage regulators cost a fortune ($30 for cheap Chinese one). I was considering making one using a solid state voltage regulator like a 7806
As you can see they are really cheap ($0.28) and are better than the stock ones because they actually produce a constant voltage no matter what the input is. My questions is has anyone done this? What voltage should I shoot for (5V, 6V, 8V?) Also does anyone know what the max current draw is on the gauges, most of these seem to only be good for 1.5A.
Of better yet, I looked on ebay for DC power supply and found lots of ones that can handle much higher currents like this one
