Help !!! STC "Fast" Trac Top
  • Help !!! STC "Fast" Trac Top
    I am installing my new STC Fast Trac Top and ran into a lil problem, here's the scenario...........
    I just finished installing all of the hardware and went to install the door frame pieces. I am running hard doors. I went to fit the "horizontal piece" into the eyelit on the windshield riser and the large hole on the "rear bow", and I am probably 2 1/2" - 3" short (yeah I know, that's what she said. The story of my life ) The "rear bow" is as far forward as I can get it to go, it's actually resting on the roll cage. I'm hoping that my roll cage is not too high. I don't have another bronco here to take measurements, so I was wondering if someone could help me out.
    1. What is the vertical measurement from the floor board to the bottom of the bow?
    2. What is the horizontal measurement from the top of the windshield frame to the bow frame for the soft top. I am coming up with 41", and my hunch is that my roll cage is interfereing the bow frame being able to come forward enough
    Any help with these questions would be appreciated.
    I just went to look for the camera, and apparently it has been MIA for a few days, so I can't take any pics
    Jeff Sander
    Reno, Nevada
    1968 Project Bronco
    1966 Fuel Injected Crawler
    Sounds like a lot. I would need to be there to be of any help, but it is definitely possible that your cage tube is in the way like you said.
      Hey I got about 35 in from top of windshield frame to the bow bar, and 46 in from the floor to the bow, if that helps. Here are some views if it helps also.
      302, edelbrock heads, roller rockers, intake, sanderson shorty headers,
        Thanks for the info guys. It looks like my cage design is biting my in the butt. I can't figure out how to post pics, otherwise I would show you my delima.
        I was looking at it last night and I think I can make it work. Once I figure out how to post pics I will give you an update
        Jeff Sander
        Reno, Nevada
        1968 Project Bronco
          Here is a couple of pics that I was able to come up with. These are just some that I have on my hard drive. I'll take a couple more tonight to show my current delimna
          Jeff Sander
          Reno, Nevada
          1968 Project Bronco
            Dude that cage looks pretty tall and I imagine its contacting the bow at the sides. I look forward to seeing your fix, any chance you are just going to build a custom attachment since the cage work looks nice it would seem reasonable that you could create something to work.
            FM
              Yeah.... well....... I hate to have to post this, but since I started this thread I guess it's only right that I come clean After going through the directions, I had a feeling something just wasn't right, I come to find out that I mounted the hinge assambely backwards I guess I better lay off the Anyways it looks like it is going to work. Which is good because I wasn't about to touch that roll cage, not after what I paid to have it built. Now I just need to install my new BC Broncos lift off hinges and finish the install
              Jeff Sander
              Reno, Nevada
              1968 Project Bronco
                FM
                Actually, the bars that go from the front of the cage to the middle (just above the my head) are about an inch too low. When we built it, I wasn't positive of the height to the top of the hard top (which is what I had at the time) so I left it a little low. I learned that lesson the hard way. Not good to jump the bronco anymore, I nailed my head on the bar.
                My back up plan, like you where saying Familyman, was to build a custom bar. It's not done yet, but I hope I don't have to do that. Keeping my fingers crossed.
                Jeff Sander
                Reno, Nevada
                1968 Project Bronco
                  I do like the cage though...
                    To me it looks like you could lower your seat alittle and fly again and stop being a head banger.
                      Nice looking cage. You should at least put some roll bar padding on the area's around your head. I've hit my head on my bars pretty hard a couple of times and man was I glad that I had put that padding on there!
                        I agree
                          Thanks for the compliments on the cage I actually put some different seats in and have it pretty much to the floor. That helped a bunch. I'm planning on adding some padding above my head and along the sides in the rear, just haven't gotten er done yet Planning on getting my doors hung tonight and with any luck I'll be wheeling by Saturday
                          Jeff Sander
                          Reno, Nevada
                          1968 Project Bronco
                            Who built the cage. It sure is purty.
                            71, 302, 435, 20, spool rear, ARB front, 35's,3.5sl 2"bl
                            nodular 3rd 1350 yoke disks allaround and on the road again
                              I designed it and had a buddy build it for me. He owns a fab shop here in Reno. He does a lot of off road stuff. He's also a co-driver for Rod Hall and races the Hummers. Here's a link to his web page, I think there is a couple of pics of my 68 under his products link.
                              http://www.samcofabrication.com/
                              Jeff Sander
                              Reno, Nevada
                              1968 Project Bronco
