Does anybody know if the IAC valve on the Explorer throttle body is 100% compatible with the Mustang IAC valve that your typical A9L, etc computer expects to be controlling?
My EFI harness has a connector for an 89-93 Mustang IAC valve, my TB has the Explorer IAC valve. The wire colors are the same and the connectors very similar but slightly different. I cut a pigtail from the donor Explorer, the connector is easy to disassemble and repin. Just want to make sure they both will work for me.
TIA...
Tony
TIA...
Tony
