got the front end all torn down and ready to cut the old brackets off. but as i was measuring i noticed that the old brackets are off at least from the point i measured from. theres a set of holes in the frame so I used them as reference points. On the driver side i got 7 1/8 and passenger side I'm getting 6 3/4. I'm guessing the P.O was off but Thought i read somewhere that these bronco frames were off a 1/4 inch somewhere.
radius arm frame mounts???
Re: radius arm frame mounts???
How does that compare with another known point, such as the center of the coil spring towers?
They can definitely be off, but I don't know if the holes you're using are any more consistent than the mounts themselves. Mine were "bent" in different directions too, so were off even in angle. Almost looked like a PO had backed over a big rock and pushed the passenger side forward a half-inch or so. But no gouging or other damage is apparent, so it could have been off right from the factory.
Hmm, maybe it was bent to fix a case of the Bronco-leans? Ya just never know with these things.Last edited by DirtDonk; 02-16-2013, 01:18 PM.Wild Horses 4-Wheel Drive
Gotta love that 60's technology... They used a yard stick when built the frames for these broncos!SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
WE had heard about this too so we made sure Justins frame was square then just used the frame ends as reference points.
Yeah his was about a 1/4" off72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
I bought the extended mounts from Tom's and they located on that frame hole. So even after welding they looked off but after mounting the axles I measured the parallels and both axles were within less than a 1/16 in parallel to each other. So while they looked off they turned out fine.Last edited by Spaceburger; 02-17-2013, 02:04 PM.Relativity: Where ever you go, there you are.
Originally posted by Spaceburger View PostI bought the extended mounts from Tom's and they located on that frame hole. So even after welding they looked off but after mounting the axles I measured the parallels and both axles were within less than a 1/16 in parallel to each other. So while they looked off they turned out fine.Just a stock 1966 U13, 170 ci 6 cyl, no kiddin'.
