I would stick with a 2" as well. Most aftermarket bumpers offer a model for 2" body lifts, I haven't seen many for a 3". The 351 fits well and I can still reach most everything without my belly getting in the way.
With some fender trimming you could just run the 37's with the 5.5" lift. I have a 5.5" lift and a 2" body lift and have more than enough room with my 37's. I am almost thinking of taking 2" out of it by moving down to some 3.5" springs.
I agree with Delta, stay with the 2". If you go with 3" you will have more "Air" under the body and I don't think it looks right. Besides EB's are heavy and you don't want to put that much metal up that high. Keep your center of gravity lower and trim the fenders more to fit your tire choice.
I have finished installing my steering column, running 38.5 boggers and was wondering any mods need to be done to the stock column for a 2" BL? I welded in a slip shaft which I dont want to redo.!
I ran into binding of the shaft after lifting the body 2". I had to install a yoke at the top to match the one at the bottom..
Aaron
Aaron
So did I.
