Okay. I'm having horn issues. I am swapping a stock steering wheel back into my bronco and believe I have all the correct parts.
The steering wheel parts/horn cap are installed just like below, but when I press on the horn button nothing happens.
If I remove the horn cap and jumper either of the two contacts on the steering wheel and the steering shaft/nut (figured it's a good ground), the horn blows fine.
What the HORN is up? Seems like there is no path to ground in the circuit. It also seems like the spring that sits at the center of the steering wheel and horn button should be the path to ground, but the spring sits on the outside of the plastic insulator used to connect the button to the wheel.
Oh, the column is a 74 or 76, the turn signal switch is for a 74-77.
Anyone have any ideas?
"A careful driver is one who honks his horn when he goes through a red light"
