Right Now I'm using the WH 17" two speed fan that claims to move 2400cfm at high speed. I don't notice ANY temp drop when I manualy switch from low 1800cfm to high2400cfm speed.
My temp is holding just above 200 deg when driving normally without any load. As soon as I start to climb up a hill and put the motor under a load the temp will rise up to about 215 deg. Maybe just a skosh higher. I'd be real happy if I could keep it at a constant 200deg. HEAT KILLS!!!!!
This is a repost from the "Stuff" catagory. Seemed more appropriate under the "Tech" catagory.
I'm curious what you 351W guys are using for your cooling systems. I've got the Ron Davis radiator and the WH 17" fan right now. No shroud, No room. The fan is somewhat shrouded by itself to direct air through it.
This is a topic I've visited before but it seems like a priority now.
