Can you weld on an engine block with a MIG welder? I think the 351 is leaking water inside the bell housing. When I rescued the 351 it was in an old boat and it had a crack in the block at a water jacket below the head surface. I guess it had froze enough to crack it. I had a good shop weld it back up and rebuild it 6 years ago. I have been noticing fluid leaking out the bottom of the bell housing lately. Not much though, but it isn't oil or tranny fluid. I was thinking maybe the block started to leak again. I hope not.
![Angryfire](https://www.norcalbroncos.com/forum/core/images/smilies/angryfire.gif)
