I've noticed lately that some guys with Ultra 4 rigs and buggies are using other materials for belly skid plates like aluminum and UHMW polyethylene. I had previously used 1/4" steel sheet for a skid plate but after getting high-centered even that got a bend in it fairly easy. Plus it weighed around 50 lbs. which isn't fun to remove while laying on your back on the ground. I know that aluminum has a tendency to stick to rocks and gall, but it is lightweight and has more flex to it than steel. I was contemplating using some 3/8"- 1/2" aluminum plate supported by square tube steel crossmembers and attaching 1/2" UHMW to the bottom of that. Does anybody have any opinions on this?
Skidplate material?
Re: Skidplate material?
I would not do straight aluminum but I don't have any experience with UHMW. It seems to me like it would get gouged quickly. I am going to stick with 1/4 steel.Last edited by Rockbronco67; 02-13-2014, 10:44 AM.
I think UHMW is the stuff they make plastic cutting boards out of. I've heard it's also used on feed ramps at rock crushing plants and quarries too.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Heavy enough alum. With 1/4" uhmw will be close to as heavy at steel. But the uhmw will slide easy over rocks and holds up good. I have some 1" uhmw I don't need if you want to try that but it weighs a bunch it's 1ft x 6ft I think. It cost me 80$. I think 3/16 or even 1/8 steel would be best if you had it broke for straingth. Or make a skeleton frame for the 1"
I ran uhmw on mine, I disliked it. I found when I was climbing something the uhmw would slide me off putting my in a bad spot, where a steel plate I had "stick" to it.
If your bending it, just add more braces. My current skid was some tractor spec metal, it was hard as heck to drill.Mark Harris
Okay, I think I will just stick to using steel for a skid plate. I'll just build a better support structure to prevent it from bending.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
