Some time ago I mentioned that I have an intermitent oil spew at the rear of the motor, between the motor and trans. Only after it's been driven and not every time. I have replaced the oil pan gasket and the rear main seal, same issue. No change.
I was talking to a guy that owns a shop here and he said I should check my PCV system. Said it sounds like the pressure in the motor may be building up to the point where it pushes some oil past the seal at the rear of the motor.
Pressure relased. No more leak, until it builds up again.
Sounds reasonable to me. Thoughts?
Now Ryan is going to talk about my rig being so excited to be on the road that it blows it's load.......
