np435 install question
  • np435 install question
    is it possible to install a 435 without doing a body lift?
    Re: np435 install question
    It is possible. But pretty tough and you'll need to cut a slightly larger hole for the top of the np435. I installed mine after installing a 2" body lift and it was still pretty tight (but I did it all by myself)
    1973 Ford Bronco: 3.5" suspension lift, 2" body lift, NP 435/D20. Holley Projection, 4.56 gears.
      I did recently. Wasnt too bad, I just made a new tunnel to cover the shift tower
