Is there a way to remove the passengers side air box without removing the front fender? I may have a new use for that space...and removing the fender isn't something that I want to do.
Tags: None
Re: passengers side air box
Originally posted by California Monkey View PostIf there is, im sure you'd regret doing as im sure it would result in paint damage1970 Bronco
It's been a while, but I'm pretty sure I cut mine apart in sections to get to the bolts.
Mine was junk and I did not feel like pulling the fender because I was worried would not be able to get it back on.Mark Harris
Originally posted by welndmn View PostIt's been a while, but I'm pretty sure I cut mine apart in sections to get to the bolts.
the reason I am considering this, is that it looks like my new onboard air compressor might fit nicely in that spot. It did however occur to me that my EFI computer is mounted underneath there, which may make mounting the compressor more of a challenge... bolts running into each other, etc. I get the feeling I am heading down the path of redoing lots of things. ugh!1970 Bronco
