So my 71 has a Dana 60. I rebuilt the front 44 with discs (had them already), new master, front lines, proportioning valve etc. I was bleeding brakes and the rear brakes had fluid coming out for a bit, but then less and less fluid came out. I checked the rear res and it was full. I'm thinking of just replacing all brake lines to the drums and rebuilding the drums, but haven't found any one that has the lines for a 60. Suggestions?
Dana 60 rear drum brake rebuild kits?
Re: Dana 60 rear drum brake rebuild kits?
Originally posted by Tankguy81 View PostSo my 71 has a Dana 60. I rebuilt the front 44 with discs (had them already), new master, front lines, proportioning valve etc. I was bleeding brakes and the rear brakes had fluid coming out for a bit, but then less and less fluid came out. I checked the rear res and it was full. I'm thinking of just replacing all brake lines to the drums and rebuilding the drums, but haven't found any one that has the lines for a 60. Suggestions?
The rear brakes on the dana 60 will use standard 3/16 inch diameter double flared tubing.
You can get pre-formed tubing from any auto parts store, including Oreilly. Just ask to look at the universal brake line assortment in the back.
Pre-formed tube lengths are unusual lengths, like 8 inch, 10 inch, 20, 30, 40, etc. Not normal feet. You can use a regular tubing bender and bend to shape.
Should cost less than $10 to do your rear axle.
Cheap, easy, reliable, effective drum brakes.
I used this tubing it's awesome easy to bend and flair
http://www.amazon.com/Seamless-Coppe.../dp/B00A02C9H0
