Would bad ball joints make a klunky sound? I was wheeling Sat. Took a few hard bounces and stared getting. Some noise. Imstected this morning and have some play at the joints. They are original. What else should I be looking at?
ball joints
Re: ball joints
They could, probably depends on how worn they are. If there is play, you will never get it aligned very well, so worth replacing them anyway.
Beyond that, can you reproduce the sound by bouncing the front end while its parked?1970 Bronco
Re: ball joints
Interesting. I hate those noises - I had a front suspension "knock" for years. A friend noticed one day that under certain offroad conditions, something was touching a coil spring. It was super hard to reproduce and not at all obvious. I wish I could remember what that was... it was something really simple.1970 Bronco
Re: ball joints
Originally posted by CityHick View PostInteresting. I hate those noises - I had a front suspension "knock" for years. A friend noticed one day that under certain offroad conditions, something was touching a coil spring. It was super hard to reproduce and not at all obvious. I wish I could remember what that was... it was something really simple.
Re: ball joints
Hmm, a yanked parking brake cable too? Maybe that's the rhythmic clanking noise in your rear end? Not being personal...
If it got yanked all the way out, it's not out of the realm of possibility that whatever it was attached to might be bent out of shape inside the drum.
Or did it get yanked from the body end? Either way, if enough force was applied, maybe it's just your brake causing the other noise.
Hope so anyway. Better than a new locker. Well, not "better" nor more fun, but at least less expensive.
PaulWild Horses 4-Wheel Drive
www.wildhorses4x4.com
71 U15 3.5" WH lift, Hanson rear, cut w/33" Swamper Thornbirds
68 U15 2.5" WH lift, Hanson front, uncut w/31 BFG Explorer engine/trans
