Dana 44 positive camber
  • Dana 44 positive camber
    my dana 44 has what appear to be new ball joints and I have positive camber wearing out the outside of my tires, can anyone assist me with info on how to fix this Thanks Tim
    Re: Dana 44 positive camber
    These from BC Broncos work pretty well... give you around 1.5 degrees of camber adjustment:
    http://www.bcbroncos.com/store/produ...oducts_id=1507
    A buddy runs them and they did the trick for him. When I took my Bronco in for alignment they told me mine was pretty much neutral camber and to only worry about adjustment if it doesn't drive well. I have never looked back.
    An alignment shop will also tell you real quick if your ball joints are indeed new or worn, and they won't even try further adjustment until they are replaced if needed.
      Live axles don't run well with the type of camber that SLA IFS suspensions do. Look at pics of old, live front axle race cars and note the camber in them.
      Cross-threaded is tighter than lock-tite
        I think these might help thanks
