Was warming up the bronco in the driveway when all of a sudden it stopped. I heard a "pisst" and saw a small puff of smoke looks like the solenoid. What causes this will a new solenoid fix it?
engine died now no battery power
Re: engine died now no battery power
Lost a fuseable link wire?
It would be the main power to the fuse block... Test light time.
Grounds would be the next thing to check.2002 F250 Superduty, 7.3 241,500 miles and counting
One of the wires hooked up to the solenoid slightly melted. I think its the alternator wire. Had to leave the house will look at it tomorrowLast edited by jperry1290; 07-04-2015, 03:42 PM.1970 Bronco 302 np435 3.5 lift 33s disc brakes ford 9 w Yukon locker
Originally posted by jperry1290 View PostOne of the wires hooked up to the solenoid slightly melted. I think its the alternator wire. Had to leave the house will look at it tomorrow2002 F250 Superduty, 7.3 241,500 miles and counting
So my left post has a thicker black wire attached to the post along with the red positive battery cable.it looks like the black cable goes into the wire loom and through the firewall. Haven't been able to track it in the dash but my guess is it hooks to the ignition switch. Should I have that wire off the post? It doesnt show it on the diagram.1970 Bronco 302 np435 3.5 lift 33s disc brakes ford 9 w Yukon locker
Originally posted by jperry1290 View PostSo my left post has a thicker black wire attached to the post along with the red positive battery cable.it looks like the black cable goes into the wire loom and through the firewall. Haven't been able to track it in the dash but my guess is it hooks to the ignition switch. Should I have that wire off the post? It doesnt show it on the diagram.2002 F250 Superduty, 7.3 241,500 miles and counting
Replaced the relay when I pulled off all the wires. Replaced the fusible link and fired her up. No issues in the 15min that I drove around. Did not see any shorts or any other wire issues.1970 Bronco 302 np435 3.5 lift 33s disc brakes ford 9 w Yukon locker
Originally posted by jperry1290 View PostReplaced the relay when I pulled off all the wires. Replaced the fusible link and fired her up. No issues in the 15min that I drove around. Did not see any shorts or any other wire issues.2002 F250 Superduty, 7.3 241,500 miles and counting
