I have been able to find out answer's too most of my questions through search's, but this one has gotten me thoroughly confused. I put a GM HEI distributor into my 74 bronco and didn't realize there was a resistor in the factory harness and I'm not getting the 12v needed to run correctly. I know I need to bypass/remove the resistor, but what's confusing me is the fact that there are two other wires with the resistor wire that tie into the positive coil feed under the hood. So, do I run a wire directly from the ignition switch eliminating all three wires or do I just eliminate the resistor and tie the three wires back together to feed the single wire going to the coil?
Any info to get this squared away would be helpful
Thanks,
Aaron
Thanks,
Aaron
