Ive had the fitech on for about 4 months now. Almost everything is working great. The only problem I am having is when I get out of the throttle while still in gear the afr goes up to 20-1 and it back fires out the exhaust. I've made small adj and large ones and nothing helps. Anyone run into anything like this? What adj have you made to the tune? Any help is appreciated.
who is running fitech
Re: who is running fitech
Interesting issue. Is yours controlling the timing too, or just the fuel?
You might call and talk to Justin at Wild Horses, as he's running one on his hopped up engine. Don't think he's had that issue with his, but it would be worth checking in to i would think.
Have you called their tech line to ask them?
Good luck.
PaulWild Horses 4-Wheel Drive
Mine backfires coming off a high rev because i need to time the engine a little better.
Call fiTech. they can walk you through step by step and try to figure it out. They helped me tons when setting my tps and idle.{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
Hey trying to rehash this forum. I am currently contemplating switching from my fox body fuel injection to a Fitech setup. I was wondering how it was working for everyone?and if it would be a good upgrade from my current EFI setup? It has a high idle issue that I have been trying to fix. And I'm am frustrated with. How does the fitech work on road off the road in the rocks? Thanks Evan
When you set your idle on your Mustang EFI, did you unplug the spout connector and the Idle Air Bypass also? If you unplug both then start the engine and close your throttle stop until it starts to stumble you should get rid of the high idle when everything is plugged back in.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
Yup I have even gone as far as replacing all of my sensors. Like the TPS idle air control Bap sensor water temperature mass air flow it has me stumped. The only thing I have not done. is replace the ECM! I am running a A9l that I pulled from one of my old mustang that ran good
