Anyone using Bosch 24lbs. Injectors on there Ford EFI conversion? Looking where to purchase some new ones. Summit has Accel brand , any input on this brand?
Fuel injectors
Re: Fuel injectors
The Accel's were a great setup, and usually sold in matched sets too.
I have no idea if that still holds true though, as most of the Mr Gasket companies were absorbed, sold off or simply closed up after the most recent shake up. Not sure if Accel is even a brand anymore(?) so you might check into that.
Pretty sure that if you buy them from a big vendor they would stand behind any trouble you might have, but if you're purchasing from a small place that's just liquidating old stuff, you might not have as much luck if you have a problem.
You can check to see if Accel is still a viable brand or not, but the good news is that they were always very reliable and well matched. Never had any complaints or returns on them back in the day.
paulWild Horses 4-Wheel Drive
