I'm going to be running an explorer serp setup on my brown bronco, and was wondering what I need to do to delete the A/C.
A/C delete on explorer serp.
Re: A/C delete on explorer serp.
Remove the compressor and run this shorter belt... Gates Serp Belt #KO60825
If the lower idler pulley on the passenger frame is contacting the frame, one of the ways you can make it work is with a 6 rib 60mm pulley instead of the almost 70mm pulley that it has. Napa #NBH36079 You have to swap pieces between the two, and NAPA is very proud of this part $$$. The above belt still seams to work, but I do not have any road miles on mine yet.2002 F250 Superduty, 7.3 241,500 miles and counting
Originally posted by 904Bronco View PostRemove the compressor and run this shorter belt... Gates Serp Belt #KO60825
MarkExplorer 5.0 OBDII
