Steering box hose connections
Re: Steering box hose connections
And for future reference, not all high-pressure sides are the larger. Some boxes use a smaller port. But one thing that is consistent in all boxes I've seen is that the pressure port is the farthest from the rear/seal/input shaft, and the return is closer to the front/seal/shaft area.
PaulWild Horses 4-Wheel Drive
