Just installed my T-Twin sticks tonight. Mind you before tonight I never even knew if the T-Case worked. Looks like it is OK. I hacked up the floor pan and I am wondering if I need to cut back more for HIGH. Both sticks are even when in HIGH but it looks like the lower plunger can come out more.
In LOW the sticks are not even but the plungers look like they are all the way in. IS IT NORMAL FOR THE Lower plunger to be out only part way in HIGH?? Do I need to cut more floor pan to get the HIGH stick moved lower thus pulling the lower plunger out more??
Which Stick if front or rear? No directions in box.
