I read everything I could find on this, but was surprised when the folks at Wild Horses told me I should cut off the threaded portion of the NP435 output shaft. This is going into a Dana 20. Anyone heard of this? Seemed like everything mated up ok.
NP435 swap - cut threads off output shaft?
Cut mine off ten years ago. No problems.1970 w/89 5.0, np 435/203/205, 456/locker/ARB, 4 wheel disc brakes w/hydroboost, 5.5" lift w/ext.radius arms, 3" bod lift, RS 9000's, tilt column, Hydro assist steering, 39.5" pitbull's on H1's. 4 link rear suspension. Hey brother, can you spare some change, I need parts....
Originally posted by Delta 4 WheelYou are using a 2wd NP435 and the threads are the Yoke nut threads. Cut em off, and grind it smooth. Remove the speedo drive gear if it is still on.Last edited by tortuga; 07-27-2007, 05:31 AM.
the spline was for a 4x4 with a divorced 205 correct???took me forever to get rid of the one i had{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
