When I bought my bronco there was no kickdown linkage so I am trying to set it back up using the Lokar cable #C-4 KD-20C4HT. My current setup is a stock mani with the two bbl carb on my 351.
The instructions show the cable mounted to one of Lokar's brackets, the 1st problem is if I mount the cable to the rear of the carb on one of the studs like the instructions say there is no carb linkage that swings oppisite of the throttle pull so the kickdown cable will be pulled at the same time.
The 2nd problem is it shows the bracket mounting on a bolt of the round four bolt cover on the passengers side of the trans which is on the oppisite side of my kickdown arm. 3rd, is it normal for the kickdown arm to move freely without ant tension? Any help or suggestions would be great.
Thanks,
Terry
Thanks,
Terry
