I am totally digging the finished disc conversion I did. I got the knuckles, hubs, discs and steering linkage from a 79 Bronco D44.
The F150/ Big Bronco tie rod linkage was tight and much heavier duty than stock EB.
I decided to use it instead of buying new. I got the front end aligned and centered to the frame. Then I measured and shortened the linkage. I had a machinist at work thread the steering arm for 1” X 18 RH and the drag link to 7/8” X 18 LH threads.
Aligned everything and took it out last night. It ran perfectly straight and true at 70 mph!
It is way beefier steering linkage than the EB. ZERO SHAKE and PERFECT TRACKING!!!
