Need some help from you guys that know body work because I don't.
The rig I own had be rolled by the PO and the psg door and front fender bore the brunt of the roll. It appears looking at it that the hing side of the door is pushed in at the top where it intersects the window support and is causeing the window to sit 1/2" higher on the psg side. How should I correct this - I know 68crawling replaced this piece in his EB - would that be the best bet or could I cut the section out , push the door post back into place and weld 'er back up. Need some help since the rigs this far apart might as well fix it. Oh, did I mention I also have a strait windsheild frame sitting on my side yard to replace the current one also. Thanks all. FM
