Stripped out the mounting bolts again and I am freakin tired of the constant leaking exhaust from these stock manifolds. Having said that...they are cheap on Ebay. Any input on good headers cheap. I know WH has good ones, but they are $400.00+. Let's hear what you guys think.
FYI...302...two inch body...435...5.5 lift standard d44
Another question...The stock manifolds meet the pipe via two stud bolts coming out of the manifolds. The pipes on mine are simply flared and a doughnut ring thing clamps between the pipe and manifold for sealing. This is where mine leaks all the time. I keep tightening them up and eventually crack the manifold or strip the bolts/nuts. Better ideas???
