Here is the situation. I have a 74 Bronco with a 90 Mustang HO that was installed about 4 years ago. I have a 24 gal standard tank from BC with a stock side tank. I have high pressure external pumps on each tank before a switch valve to select which pump and tank are selected. These are both external pumps.
The problem that I am having is that the vehicle will run for sometimes up to 2-3 hours without missing a beat. All at once it will start sputtering and die. Sometimes I will switch tanks and it will fire up again and run right away. I will run on that tank for maybe 15-20 minutes, switch it back andrun for another couple of hours. Sometimes, I have waited about 5 minutes without switching tanks and it will run again for a long time.
Both of the external pumps are located close to the tanks with truck type filters between the pumps and tanks. I have changed the filters often without any improvement.
Any and all help would be appreciated
