I fired up my 5.0 efi conversion for the first time, it idles smooth runs fine, the only thing is, is that im getting one hard code #22 Map Sensor out of range, it is a new sensor but its for a 86 speed density motor so im thinking thats the problem, i started going speed density, then switched to Mass air, im going to call napa and see if the 86 and 89-93 map sensors are 2 different part numbers.
It's Alive!!
Well i think i figured it out, 86-88 ford used a MAP sensor, 89-93 they used a Barametric pressure sensor BP, they both have same plug and the port for vacum, but they are 2 different part numbers. so im sure they put put different readings to the computer.
Nothing like posting in Tech forum to talk to myself and figure things out lol.EFI 5.0, NP 435, 5.5 WH lift, Duff Arms, HP 44 front, 37" MTR's
Originally posted by Chips67 View PostNothing like posting in Tech forum to talk to myself and figure things out lol.
Doug2002 F250 Superduty, 7.3 241,500 miles and counting
Good Job
Dam that was fast, what you got the Hareness on Mon. And done today Glad it all went well for you.It looks like the instruction are not bad. So when I ready to do mine I will buy and food so you can come and help. An EFI Tecnician is nice to have around
BrianOriginally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Yahoo!!!!
I believe the sensors are actually the same. If you are running a SD set up you run a manifold vacuum line to the sensor. If you are running a MAF set up, you plug that vacuum port on the sensor. The part # that is for the 89-93 Mustang comes with that port plugged already.
Congratulations on getting her running!! Have you driven it yet?Last edited by crawlin68; 02-15-2008, 02:22 PM.
Congratulations on getting her running!! Have you driven it yet?69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
Originally posted by Delta 4 Wheel View PostSweet Chip! When do you wanna hit Carnagie to test out the rigs??{o===o}Originally posted by TBS-POPSEXCUSSSSSSE ME oh RUBIMASTER!!! I forgot how Awesome YOU ARE!!! I BEG your forgivness....Originally posted by CityHickI don't give probabilities in percentage format anymore
i have not driven it yet, i need to mount the computer in its final permanent spot, finish the throttle cable, adjust the new clutch, and now i went and stepped on the brake pedal and have a brake line leaking lol..figures.EFI 5.0, NP 435, 5.5 WH lift, Duff Arms, HP 44 front, 37" MTR's
The code 22 problem i was having was simple, i had a vacuum line going to the BP sensor, you dont need it for mass air, so now i have an extra sensor for the trail parts box.
The engine runs perfect, super smooth idle, quick response, and no codes on the computer now, hopefully it will run the same on the street. Sure does run good in the driveway though.EFI 5.0, NP 435, 5.5 WH lift, Duff Arms, HP 44 front, 37" MTR's
Wow,
You don't mess around, that was quick! Get those brakes fixed, and give us the test drive report. Glad to hear is was trouble free, I hope my EFI install is 1/4 that smooth.
GalenOriginally posted by 71BRONCO71 at Buck Island 6/25/11I can do that so much better myself..........1, 2, 3 GOODNIGHT!!!
