OK heres the history:
Drove it almost everyday for the last 4 years, never a starting problem.
After work I parked it in the garage, next morning it just cranked and cranked,
never even tried to fire. After work, checked for fuel (1/2 tank) getting to the carb, Yes, checked for spark at coil, all plugs, yes, pulled #1 plug, got engine to TDC, dist. rotor pointed to #1 on the cap. Pulled valve covers, everything looked OK, push rods, rocker arms all moving up and down so I think cam is not broken. Only thing I can think of is the timing chain and gears may have sliped making it just out of time to not start.
Almost forgot, I bought a new ignition control box, (the right one after two tries) didn't help.
Had 2 guys that know alot about engines take a look, no help no solutions.
So I'm leaving this up to you Bronco gurus for help.
Thanks for reading this long post.
Joe
Joe
