Gas Pedal Return Spring
  • Gas Pedal Return Spring
    anyone use this spring? is it worth having ?
    What do you mean? Every Carb should have a spring on the throttle plate/butterflies..
    KK6DAD
      I'm using one from the carb back to a bracket bolted down using 2 threaded bolt holes in the intake.
        no, the spring under the gas pedal..so it pops back up lol !
          I don't have one there.
            I do not remember any such spring from before I tore my rig down, and can't even place where it would go. Got pictures?
              Love the pedal spring humour, I had to add a couple to my EFI setup to get it to work/feel right.
              Rick-
                only picture i have seen is the one in LMC catalog..shows spring on back of pedal..i tried to put new pedal on with assembly in bronco..but finally decided to pull the assembly out..it needed paint anyhow lol P )
                  Dude..........place the tools on the ground, and step away from the Bronco, you're overthinking it.
                  Brad
                  Chico, Ca.
                    it will look better painted anyhow lol P )
                      Ooohhh, that spring, looked before I left for work today and NO spring there.
