Just got done doing the chebby heater motor upgrade. Puts out alot more air but I will have to turn up the stereo now. It's alittle loud on high.
Here's the long and winding post on the CB site.
http://www.classicbroncos.com/forums...t=chevy+heater
Very easy mod. You will have to enlargen the hole in the front on the heater box to allow the new fan blade. Wiring is a snap, ground wire from the heater body to the back of the metal heater box, power wire is the same, just a differant type of connector. It's alittle loud on high but it does put out more air. I would like to find a 3 way switch to wire in to have a 3 speed heater. Guess I will have to start looking.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
you can use the stock blade however I think you will need to make some modifications to the back of the heater box as the chevy motor sits alittle farther into the box then the stock motor. I think the stock blade will hit the back of the heater box.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
I had to remove mine to replace the heater core but I guess it could be done in the truck.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Re: chebby heater motor upgrade.
I just did this. Chevy motor with stock fan and it fit fine... no grinding or enlarging of the box. Took all of about 30-45 minutes. It puts out so much warm air it almost makes me forget that I only have tube doors and no top!SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
I did the Chevy Motor/Fan about two years ago. Dispite the brand, it was a big improvement. Easy upgrade to do! When I did mine, I took out the box, replaced all seals and core. I was as snug as a bug when we wheeled in at night for Holloween. I would recommend the project to everyone.Leave No One Behind
KK6AUW
I was going to do this upgrade this year but then we didn't get any snow... what part numbers did you use? Might as well go pick up the parts now. Thanks'68- 302 C4 x D20, Dana 30 x 9" stock gears, 33" pavement pounders, 3-1/2" suspension lift 0 body lift, wishlist getting bigger, wallet getting smaller
Originally posted by JusticeJMB View PostI was going to do this upgrade this year but then we didn't get any snow... what part numbers did you use? Might as well go pick up the parts now. ThanksLeave No One Behind
KK6AUW
