Okay...tired of the leak. So I remove everything...loosen the crankshaft bolts drop it down, remove the upper seal. I cleaned out the silicone that was put in there by the prior owner as best I could. Bought the new seal, installed it in the right direction, clocked it a bit so the seal ends were offset from the cap/block...about 1/4 inch, put a couple dabs of sealant on the ends of the seals where they meet and reinstalled button it up.
Still leaks...now worse. I now think there was a reason the prior owner loaded up the gasket with silicone. is there anything else I can do? Tricks, Ideas?? FYI...the crank has a line on it where the seal rides, but I would not describe it as worn into the crank. And yes, again, I installed the seal in the correct direction.
Marlon
Marlon
