Windshield Quick connect?
  • Windshield Quick connect?
    I'm looking at removing my windshield, but I'll have to cut the wiring. Does anyone have any suggestions on how to wire it up so I can have a quick connect. I'm thinking I'll have to enlarge the hole. I know I'm going to remove it again when it goes to paint.
    __________________
    '67 EB, 5.0 EFI w/ Explorer Serp, 3 1/2" Lift, 1" Body Lift, Chevy Disc, Crab Family Cage, Future Plans: NV3550, Paint
    ECV
    Re: Windshield Quick connect?
    Don't cut your wires. If still stock, it disconnects somewhere behind the dash and the connector can come out with the windshield frame. I painted my windshield frame with the wiring still routed through it. Its one of those 4 or 5 pin rubberized Ford connectors found all over the stock harness.
      It disconnects right by the wiper motor. I don't know if the connector is small enough to go down the frame channel though.
      Brad
      Chico, Ca.
        Right it disconnects there and also under the dash. Or at least mine did.
          It actually has been rewired with a Centec harness, I'll look deeper under the dash tonight.
          __________________
          ECV
            If it has a Centech harness then it does not disconnect under the dash. It could easily be made to though. Just cut the wires and buy a 4 pin GM style water proof connector at your parts dealer of choice.
            Brad
            Brad
            Chico, Ca.
              Thats what I am thinking but then I'll have to expand the hole so I can pull the windshield off. No biggie I guess.
              __________________
              ECV
                GM Weather pack connector, tower and shroud sections, and terminals/dust seals. After you install, buy the tool that removes the connectors from the shroud/tower, then they can fit through the hole.
                  I am a big fan of the weather pack connector! I've put a $hitload of them in my rig!
                    I was out of weather pack connectors when I finally got around to doing the wiper motor on mine, so I ran to kragen and got a 4 pin trailer harness. The kit had both male and female sides, I soldered/shrunk wrapped the wires on and presto, wiper disconnect for about $3.
                      Excellent topic as I was thinkin about the exact same thing as I dont want to trash my windshield frame while competing in the Can-Rock series next year after I get some seat time with mine.
                        Good point. I folded the windshield on my heep by laying the top off it against the side of a pine tree after I slid off a ledge with my nose in the air. I should have removed it first.
                          This is the reason I can take mine off in a couple of minutes. I have the advantage of not having wipers though.
