Whats everybody doing about the holes left behind from the factory molding strip on the sides, welding them up, sticking buble gum in them or buying new fenders gonna get a fresh coat of paint this winter.
those tiny holes
Re: those tiny holes
I welded mine with a Lincoln 110v wire-feed welder without the luxury of gas, ground them as smooth as possible then skim-coated with Bondo. All told it came out pretty decent, but I am the first to admit I didn't do a perfect job, but if I did that just means I'd rub against an immovable object that much quicker!1970 Bronco
welded and bondo'd them. Still have more work to do.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
get out your old acetylene torch and braze them over! make sure you cut the paint first and sand the whole thing including the metal around the braze before you apply bondo (if you have to apply bondo) alot of the time you can use a thick primer to take care of it! and dont forget your metal etch! (Back side if possible too) brazing is just about as strong as welding and you dont have to worry about messing up your original metal or backing it with something (because it fills very well)
just thought I would throw my two cents in!'67 4bbl 351w 3spd 4.11 3.5'' 33'' Workin Project!
Most people will never imagine what Me and My Bronco have been through.
It's quick and painless, just go slow and build it up! add a little back off, heat it up again add a little more and then cut it straight with something coarse! and move to the next.
Not to worry you or anything, but I have seen warped steel from brazing... you shouldnt have to get anywhere near that hot!
Just use a little common sense and lots of beer... afterwards!'67 4bbl 351w 3spd 4.11 3.5'' 33'' Workin Project!
