Laquer over urethane enamel or???
  • Laquer over urethane enamel or???
    How does Laquer do over urethane enamel? I can not rememember is it enamel over Laquer or laquer over enamel. I know it is only one way.
    1974EB 302v8, NP435, dana 20 twinstick, dana 44, 9 inch Detriot Locker's, 4.88 gears, front disk, Rockbox, wild horses 4.5 inch lift, 4 wheel Warn Full Floater, 35 Super Swamp Bogers.
    Re: Laquer over urethane enamel or???
    I think it is Rustolium over Krylon.
      I believe its ok to shoot urethane over lacquer but not the other way around.
        What is the original paint on Broncos?
          I think it's imaron? Isn't that laquer?
          73' balanced .060 302, NP435, 1"BL, 2 1/2 "pops" susp lift and more to come!!
            enamel
              I'm fairly certain Imron was not the OEM paint on Broncos. Imron is polyurethane enamel.
                Summit Racing sells paint that is Acrylic Urethane, $89.95 for a Gallon, I think even with the reducer and activator it is still under $120. I think I will try that. But on their website it says shipping restrictions. I might have to drive up to Summit to buy it.
                  laquer over enamel is ok, but you definately dont want to try enamel over laquer! and why would you use laquer unless it's an old model T or something that came with it? (it's easy to shoot... but a pain to keep up)
                  C&H Paint off of broadway in Sacramento used to be a good place to get (PPG) a pretty decent paint.
                  Using inexpensive enamel is ok, just make sure you do a good job with the prep work.
                  '67 4bbl 351w 3spd 4.11 3.5'' 33'' Workin Project!
                  Most people will never imagine what Me and My Bronco have been through.
                    check out
                    www.tcpglobal.com
                    for all your painting needs
