Think 16x8 with weld on beadlocks both sides clear the brakes?
double beadlocked 16s
Re: double beadlocked 16s
Did you find a good deal on the wheels in question. Because Stazworks makes Humvee style double beadlocked wheels, so does Hutchinson(Rock Monster) and USA6x6. I think it would be really close if they did fit. But have if you had pinch style beadlocks it would be a nightmare to balance your tires and they would probably also give you issues with air leaks.SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
You can get pinch style bead locks to seal decent. I only have to ad air to mine about every other month. I know mine have a litte shake to them, but I don't have any weights at all on mine. Centering the tire on the beadlock ring is critical also.Marc D.
I got me a set of AR767 16x8s or perhaps they are 10s off a bud, sight unseen as they are brand new for 150 CDN.
Picked them up so I would double my chances of finding 38.5x15wide Boggers or SX cheap as I now have 15x10 Eaton Beadlocks and with the 767s I can convert those to beadlocks as well.
What about the Staun beadlocks? Innertube against both inner and outer bead of the tire?74, Banana yellow, on 4-Ton Jack stands, waiting for more overtime. Soon: 37's, NV4500, Atlas, Full width 44/9" sigpic
