Tire sizes
  • Tire sizes
    I have a problem with the front tires rubbing on the rear fender well. I am running 33" with Wildhorses system 9 suspension (3.5" lift,2' body, same as system 10, without radius arms).Click image for larger version
    Re: Tire sizes
    Wow, I run 37's with 3.5 lift, and 1" of body and don't hit like that. Do you have some crazy backspacing or wheel spacers? Is that the inner fender, or the firewall you are hitting. I don't have inner fenders on mine.
      Re: Tire sizes
      Impressive for just 33's! your backspacing on the rims are prob off (3.5" seems to work fine) and I would invest in some bump stops to save the tires from the 'body siping'
        Re: Tire sizes
        Sawzall.
        Dusty
          Re: Tire sizes
          never seen the front flex like that.. what kind of goodies are in the front...
          never hit my sheet metal
            Re: Tire sizes
            bad to the bone
            this isnt the WH project truck is it??
              Re: Tire sizes
              something not right here.. look at the steering linkage and the cross member.. hmmm
              KK6DAD
                Re: Tire sizes
                Originally posted by 71BRONCO71 View Post
                bad to the bone this isnt the WH project truck is it??
                It was...
                I was there - I think its an optical delusion Aaron. His steering was not going to hit the crossmember.
                His front suspension is nothing special - 3.5" springs on stock radius arms. It does flex well! I do not understand though why his 33" tires are rubbing when others with that configuration can run 37" tires with no rubbing.
                Anybody have any other ideas? I've been trying to convince him to go with 37" tires but he proved to me that he's got clearance problems with 33's. It would suck to put bigger bumps on the front of that rig because you'd lose so much bump travel. As you all saw it does flex nice.
                His wheels are 15x10 with no less than 3.5-4" of back spacing. The tires are 33x12.50. Is it possible that his springs have just sagged so much that he's actually sitting a lot lower than most who run a 3.5" lift? I didn't think the coils ever sagged that much.
                  Re: Tire sizes
                  Looks normal to me. When I had a 3.5" lift, 1" body, and 33x12.50s on 15 x 10 wheels mine stuffed both front and rear tires into the inner fenders. The front is real easy to clearance by cutting back the inner fenders. An 8" wide wheel would help in the front.
                    Re: Tire sizes
                    You say stock ad arms??? Dude my stock arms maybe move a total of 8 inches. Need more detail? Is it due to the steering set up?
                      Re: Tire sizes
                      I assume it does not have drop radius arm brackets as well? (and it should not as they suck).
                      When you lifted the truck, with the stock radius arms, you loose about 1 inch of wheel base with the swing of the radius arm mounted in the stock bracket.
                      Your wheel choice is not helping.
                      Lets see some side shots.
                      Also measure your wheelbase from Center of the rear axle, to center of the Front hub.
                        Re: Tire sizes
                        Could it's being stuffed like that have something to do with a 3.5" spring being shorter than a 5.5 spring when compressed? Just my uneducated view on things.
                          Re: Tire sizes
                          WOW Is that the Vicodin talking?
                          KK6DAD
                            Re: Tire sizes
                            I took 3
                              Re: Tire sizes
                              I have the Cage drop bracket, but I am using the upper "stock" hole. My wheel base is about 92.5". I just installed a new pair of wildhorses angled rubber radius arm bushing (frame side).
                              I bought the rig about 2 years ago from a guy who had all the original Click image for larger version
ID:	259061paperwork from wildhorses.
