I am getting ready to install my rear hoop. I do not have the install instructions. Anyone have a set or at least know where to weld the mounts?
Cross Rear Hoop Installationinstruction
Last edited by kwspony; 04-06-2009, 12:48 PM.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!Tags: None
Re: Cross Rear Hoop Installationinstruction
IIRC the lower mounts are supposed to be ~ 4" outboard from the pumpkin...'88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
Re: Cross Rear Hoop Installation instruction
Thanks Sean. I was wondering, If I wanted to go with a longer shock, could I move them out a bit farther?Last edited by kwspony; 04-06-2009, 12:48 PM.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Guess you could, but plan for any future upgrades as well. I had to cut one off and move it to the rear when I built my anti-wrap bar....'88 347 roller, Exploder EFI, WH Shorties, NP435, twin stick D-20 with Tera lows, 44 4:56's w/ARB chromos and CTMs, 9" Detroit, cust dash, wiring and STILL ALMOST "DONE"!...
Do you get alot of roll with those? I bought one to replace duff mount, But I was told I would get alot of roll on the road.sigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
mine rides better with the inboard then it did with the stock setup, course i did FW at the same time.
Body roll is all about the shocks. I went with Phil (sillyfabs) advice and went with procomp3000 and I love'm. And for 28 bucks a piece who couldn't.
My shock mount is on the front of the axle all the way out next to the spring perch. and bolted to the inner most hole.72' in pieces and piles of awesomeness
Is the upper mount straight above the lowers or at an angle?1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Please check Rick, I hope to get it in this week. Thanks.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Left ya a msg, but: leaf spring perch inner (towards diff) to lead (outer) edge of lower mount is 4". Upper hoop is mounted directly above the axle housing (use bump stops as a reference) flush with the bottom of the frame, 1/4 - 3/8" below the floor (with a body lift go as high as you can and still keep a good weld, what I did, longer shocks, your choice here, my input-install)
Thats what it says with my extra input. Have fun 'bro you will love the flex. Give me a call if you need more info/clarification
Rick-68 Slightly modified
thanks Rick. I was under the bronco when you called. I got the mount mocked up and measured. 18-20" depending on which hole I use.1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
Rick, are you running 10 or 12" shocks in the rear?1968, 69 351W,NP 435, Stak 5.22, D44 with 4.10's, chebby discs and a detroit, 9" with 4.11's and a lockright. 35" MTR's, TRO, WH cage, ps, pb, 3.5" susp, 2" body lifts, pile of parts in the garage, empty wallet!
