I have zero faith in my current power steering hoses and I really dislike my PS cooler setup. Also, the hose routing I came up with makes for a very non-serviceable driver's side of my engine bay. Before I get left stranded by failed PS hoses I want to redo them the right way.
I am running a stock Bronco PS box so the fittings for it should be 11/16-18 and 5/8-18. Can anybody confirm this? Seems to be the consensus here and on CB - so I'm pretty confident this is what it is.
For the PS pump fitting - can anybody confirm which fitting is on the back of a serpentine-driven Saginaw pump? Mine is an Econoline van Saginaw pump (late 80s/early 90s van 5.0/5.8). From what I have read it might be a metric fitting, 16MM X 1.5 I.F. male. Can anybody confirm this? If its something else, what is it?
Finally - How critical would everybody say a PS cooler is? It would sure clean up my hose routing to not have it in the loop, but something tells me if nothing else, it serves as a reservoir, providing more PS fluid carrying capacity which is probably a good thing.
Any input? I'm trying to figure out what I need before disassembling what I currently have and I know I'm not the first to run this configuration.
TIA...
-Tony
TIA...
-Tony
