Does anybody have a part number for the axle end seals needed when running 31 spline axles in a small bearing housing? I just discovered that my shafts don't go all the way in and they get hung up on the old seals as the axle gets larger right towards the end where the bearing rides. The bearing OD is fine and matches the old bearing OD - but the seal isn't going to work, and its too late for a WH run... So much for driving the rig this weekend
Any help would be great - if this is an auto parts store "on the shelf" item that would be sweet.
