Has anyone ever installed a custom Ford 9" in the front of their EB? If so do you have pics.
9" front dif
Re: 9" front dif
That would be a 609,, 9" w/60 outers. looked into it and decided it wasnt worth the expense...72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Re: 9" front dif
Okay then if I stick with the D44 I have the L.P. v.s. H.P. dilemma. I currently run a stock L.P. drum D44 in my 71' EB. I am going to run 3.5" of susp. lift and 2" body lift with 35" - 36" offroad tires. When I wheel I wheel some rocks/trails/mud/snow , but mostly trails. I did look at some Reid Racing D44 flattops but I did not know someone made 35 spline shafts. When I posted up questions about flattops everyone waas telling me to go H.P. I did not think a h.p. d44 would work to well with only 3.5" of s.l. So here is my quandry. I do like the D44 because I know they can be built tough and for the type of wheeling I do it would suffice. Open to opinions.
Re: 9" front dif
It also depends if you are going to be doing highway driving or flat towing, because the HP doesn't oil as well.70 rebuilt 302, Edelbrock Performer intake and carb, C4, 20 w/aftermarket gears & HD output, D44 w/Power-lock, disks, 4:88, 9 in Detroit, PS, PB, winch, lights, rock bumpers, full cage, 3 1/2" WH lift, 2" body lift, IROK 37's, 23 gal tank
Re: 9" front dif
A HP D44 will work with as little as 2.5" of lift. But the slight added strength of the HP isn't really worth the expense unless you have driveline bind issues . Putting 35 spline shafts in a D44 will cost more than a D60, and you will just start breaking ring and pinions instead of hubs or shafts. A "609" would be sweat but for the expense I would rather spend less and get a D60.Last edited by highlander; 04-28-2009, 08:14 AM.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
Re: 9" front dif
Originally posted by Sierra Backwoods View PostIt also depends if you are going to be doing highway driving or flat towing, because the HP doesn't oil as well.Last edited by highlander; 04-28-2009, 08:14 AM.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
Re: 9" front dif
But if I go D60 then I have the weight issue. Right now I have the D44 l.p. stock...It seems to me that I could beef it up for less than buying a D60 F or 609 but I may be able to get a D44 h.p. for less than either of those . I do some hiway driving but not flat tow. I do not believe the driveline angles are an issue with 3.5 " of lift and stock drivetrain, I do not think I need too much strength as I do not wheel hard. So the cheapest upgrade for now would be to beef up my l.p. D44. Thanks for all the input. Now I have to go to the wrecking yard and pull out some catalogs and get my stock drum brake l.p.
D44 some discs/flattop knuckles/ 35 spline shafts /ctm's/ tube steering components. And if I break then maybe I will look at upgrading to a D60 or
"609" .
Re: 9" front dif
Originally posted by highlander View PostA HP D44 will work with as little as 2.5" of lift. But the slight added strength of the HP isn't really worth the expense unless you have driveline bind issues . Putting 35 spline shafts in a D44 will cost more than a D60, and you will just start breaking ring and pinions instead of hubs or shafts. A "609" would be sweat but for the expense I would rather spend less and get a D60.
Also, no need for flat top knuckles. Those are only for running high steer arms for your steering, and EB's don't need to be lifted that high to run high steer arms. With only 3 inches of lift, the high steer arms would hit the frame.Mark Harris
Re: 9" front dif
Originally posted by welndmn View PostI agree. The best option is to just swap to full width axles, it almost cheaper then putting money into a stock EB Dana 44.
Re: 9" front dif
I sold a BUILT 44 To go to a HP60 that way I don't have to look back. Save some money build a 60 once.Originally posted by TBS-POPSAfter a huge amount of reflection, I have determined that what I saw in ukiah was in fact Brians bronco. I was also informed by my wife that she infact heard it run!!
Re: 9" front dif
What are the pros and cons of fullwidth? Isn't there alot of modifications to do fullwidth properly like cutting the wedges off and mving them in 3" on each side? I believe a friend went fullwidth and he used a 76' f150 as a donor and cut the wedges ,bought new wedges and welded them back on inboard 3" on each side and set the proper caster. I have read about guys moving the buckets out on each side but this does not sound streetable.
Re: 9" front dif
The only con i have for having full width is that sometimes you see guys go around obsticles, and well you get to go over them.
Install is to easy. No rotating or moving wedges, just a change in your radius arm mount at the frame.
I second the ixna on the flat tops, a simple TRO or REO will suffice.
Also save yourself some cash and look into OX or longfield joints $100 a side cheaper. Longfields are made of solid 300M.72' in pieces and piles of awesomeness
Re: 9" front dif
The biggest con I can see is not being able to fit between the posts on trails such as Barrett Lake. I do not remember the width measurement but I have heard it described as "nothing wider than an early bronco" can fit through. It would be a big deal if CA started putting those posts at the head of more trails.
Otherwise FW looks cool and adds stability. Plus with the proper wheel backspacing sometimes they don't even look that much wider.1970 Bronco
