Have shifters but nothing else. Also looking for ideas for the shifter on the 203doubler.
Twin stick linkage and direction sheet for Tcase
Re: Twin stick linkage and direction sheet for Tcase
Wild Horses has most of their instructions on their site.
J-shift
http://www.wildhorses4x4.com/downloa...2008-08-06.pdf
T-shift
http://www.wildhorses4x4.com/downloa...2008-08-06.pdf77 Ranger, 302, C4, 4.88's, Detroits, 35 spline 9", WH 5.5", 3" BL, 37" BFG KM2's on Walker Evans 17" beadlocks
Originally posted by fordnut77 View PostWild Horses has most of their instructions on their site.
J-shift
T-shift
http://www.wildhorses4x4.com/downloa...2008-08-06.pdfsigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
Originally posted by Broncrick View PostAll I have is the same as above for the Dana T. I have the tunnel cover off if you need pics Gregsigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
Originally posted by u14 View PostIf you dont mind Rick that would show me the linkage. Then I can make my own. Agian guy's thanks.77 Ranger, 302, C4, 4.88's, Detroits, 35 spline 9", WH 5.5", 3" BL, 37" BFG KM2's on Walker Evans 17" beadlocks
Thanks agian for all the info. Next week I will tear the D20 apart and do the rails. Should I go ahead and put a deluxe rebuild kit and extreme output system in it?sigpic70w/ 69/351w/GT40 lightning heads 435/203/D20 5.5/3in 44/arb 9in/detroit need some beadlocks
Be the perfect time to do it..1970 w/89 5.0, np 435/203/205, 456/locker/ARB, 4 wheel disc brakes w/hydroboost, 5.5" lift w/ext.radius arms, 3" bod lift, RS 9000's, tilt column, Hydro assist steering, 39.5" pitbull's on H1's. 4 link rear suspension. Hey brother, can you spare some change, I need parts....
Originally posted by blwngsket View PostBe the perfect time to do it..1970 Bronco
Is it true that with a Dana 20, you can't use it in front drive/rear neutral unless you modify the shift rails?SOLD: 1975 Ford Bronco: 105" wheelbase, King 14" c/o shocks, King 2" air bumps w/ Duff arms, 4 link rear w/ coils. Fuel injected 408W, ZF 5 speed/Atlas II(4.3) and Dana 60/70 axles with 5.13 gears and ARB's, 41.5/13.5R17 Pitbull Rockers on 17" Raceline Monsters.
true, as with all stock t-cases...72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
