I bought a proportioning valve for disk brakes, but like the idea of the adjustable one. Some of you probably have ran both. If so, what are your thought's?
Proportioning valve
Re: Proportioning valve
Is it a proportioning valve for 4-wheel disk or front disk rear drum?
I too like the idea of adjustability but on the other hand its just something else to screw with. I have the non-adjustable prop. valve from WH for disk/drum and it does the job well. My rig stops pretty well for running 37" tires!1970 Bronco
With 44's better brakes will come with upgrades and spending $.
A proportioning valve does nothing but restrict fluid flow / pressue to normally the rear brakes so they don't lock up. You restrict them until they lock at the same time as the fronts.
With 44's unless you already have nice brakes, I don't think you are locking them up right?Mark Harris
Adjustable is always better than non.. you can fine tune it for your particular vehicle and the weight transfer it shifts when braking..every vehicle is different... Better braking with 4 discs needs a larger bore MC, the P-valve will only keep the rears from locking before the fronts,NOT improve the braking...Lock-up is max breaking force, you just have to control it....hence anti-lock brakes.... for vehicle control and safety... class over72 sport/exp.,TBI 302,NP435,4.56 Powrlok/ARB in Full Width's.5.5" CAGE lift w/arms,2'' bl,37's, rescued from the concrete jungle (L.A.) NEVER DONE!!! Sold to buy a Boat, Now Broncoless.....Now it's fast water,smooth women and cold beer!! toad jeep owner now,,,,,, sorry
Originally posted by TBS-POPS View PostAdjustable is always better than non.. you can fine tune it for your particular vehicle and the weight transfer it shifts when braking..every vehicle is different... Better braking with 4 discs needs a larger bore MC, the P-valve will only keep the rears from locking before the fronts,NOT improve the braking...Lock-up is max breaking force, you just have to control it....hence anti-lock brakes.... for vehicle control and safety... class over6 jeeps 2a-cj5. bronco now. 70,efi 302,c4,ps,pb, 4.56's detroit's 2bl,4.5 rollin on 37's
IMO, if you're not locking up your tires, you don't need a prop valve yet.
I would spent the money on a Master Cly, or better calipers.
I run the normal 1/2 ton GM calipers with a Wilwood Master Cly and my rears lock up easy, stand on it on it, and fronts locks.
All Manual brakes for me as well.Mark Harris
