Looking to see which Master Cylinder seems to work for Disc/drum combo non Power. I'd like to keep the brake lines where they are (Driver side) of Master cylinder. I see the FOrd F-250 with dual piston calipers may work. It shouldn't be an issue if I only have single piston should it? Just a larger reservoir?? Thanks
Which Master Cylinder
Re: Which Master Cylinder
Originally posted by broncsport74 View PostLooking to see which Master Cylinder seems to work for Disc/drum combo non Power. I'd like to keep the brake lines where they are (Driver side) of Master cylinder. I see the FOrd F-250 with dual piston calipers may work. It shouldn't be an issue if I only have single piston should it? Just a larger reservoir?? Thanks
To remove the residual valve just remove the front brake line at the MC, should be the back one, then find a screw that fits into the cap in the port and use it to pull the cap. Behind the cap is a spring and a BB, pull these out, replace the cap and reconnect the line.
If you have a problem with the rear brakes locking up you can install a disc/drum proportioning valve or an adjustable proprtioning valve. I would try it without first most people, myself included, find they don't need them.Last edited by highlander; 05-18-2009, 06:59 AM.69, 342 EFI, C4, NP203, D20, 4.5" SL, 2" BL, 4.88 9" 35 spline ARB, 4.88 HP D44, WAH, ARB, CTM's, front disc , 37 x 14.50 Toyo MT, Ram Assist, and rear 4-link
