Gear setup - tools needed?
  • Gear setup - tools needed?
    Running out of cash to finish the rig for summer - looking for some places to cut corners. From the quotes I have, it looks like I can save around $5-600 buying R&P myself and setting them up. That number is labor + markup on gears that I can buy online for $325 or so.
    Have dial indicator, base, torque wrenches, patience (some), don't have a way to remove or press on bearings. What does it take to get those on and off?
    Is there a shop that will do that piece alone without charging an arm and a leg?
    Thanks,
    Brian
    Re: Gear setup - tools needed?
    Buy yourself a HF press and you'll never look back. $100 buys a press that'll do that and just about everything else you will ever need to do.
    In addition to your list you're going to need a bearing removal tool. They are cheap and work similarly to how a steering wheel puller works, in a roundabout way anyway.
    If you're talking about setting up your 9", you're going to need a big socket wrench (preferably the non-ratcheting type because they tend to be stronger) and as long of a cheater bar as you can find for compressing the crush sleeve on the pinion side of the 9".
    I recently had a friend help me set mine up and its actually not terribly difficult. I don't know about the D44 though.
      i have never done this but i did watch extreme 4x4 and what they did for the bearings was..
      Buy another set of bearings and use a Dremal (sp?) to grind the inside of the bearing bigger so you can test fit it on. this is all the knowledge i can give as i have never done it. but after watching Extreme4x4 i think i could now.
      Here is the episode Gear Setup
        I have all the tools. Your close by.
          Now that's Cool
            Shane (Gremlin) Is a good guy and I'm sure he will help if he can. He is a good wrench-Just have to look at some of his projects. Ask about his daily-Pretty cool.
            Jack
              I have never done the 9", but I have done a few toy 8" (almost identical to the 9").
              Its not hard but you do have to have patience. The press and bearing seperator are the most valuable tools. You will also need a dial indicator and stand to measure backlash, spanner wrench for the preload, dial or beam torque wrench in in/lbs to read pinion bearing preload.
              I will also say to use a solid pinion spacer instead of a crush sleeve, if the 9" has one.
                I'm very curious about the solid spacer idea... how does that work? The crush sleeve makes sense - you just crush it until the preload is correct. How do you do it with a solid spacer that does not crush? There must be a way to measure so you know what size spacer? Or do you run some kind of shim until its exactly right?
                Sorry for the hijack - but I know one day I'll be doing this again...
                  Maybe I'm wrong, but you could crush the crush sleave, take it out measure it, and then make your solid spacer the same size. Maybe there is a better way.
                    Geez guys. i give you the perfect video and you didnt watch??? hahaha
                    10 min 10 sec to 12 min 20 sec
                    10 min 57 sec to 11 min to be EXACT!
                    Young kid: 1
                    Old Guys: 0
                      Young kid: 1
                      Old Guys: 0
                      Watch it youngster! Damn now I feel old - a 20-something called me an old guy... but hey, I still feel 25 most of the time.
                        you add/subtract shims to get the correct pinion preload.
                        On a toyota you have to take the pinion in/out untill you get the correct shim stack. Pain in the ass but well worth the time. Once its set it won't change, a crush sleeve can always crush a little more.
                          The solid spacer that came with my master install kit for my 9" was about 1/16" too thick. It also came with shims, but because the spacer was too tall I just used a crush sleeve.
                            put it in a lathe and trim it down. The solid spacer is a much better way to go, especially for a crawler.
                              I agree on the spacer/shims instead of using the crush sleeve. It's more work to set up in beginning, but I think it's worth it. The main reason I did it was just in case I ever want/need to take the yolk off of the pinion (breakage on the trail, maintenance, ect...) you can just run put it back on without having to worry about replacing the crush sleeve. Just my .02.
