Here's the prob. I've got a set of used 78-79 F-150 knuckles (from a vendor that will remain un-named for now...O.K. service after getting wrong/damaged parts)
that I want to put onto my '69 Bronco, I have a '79 dana 44 with knuckles that have been reamed from the bottom-up for Chebby 1 ton TREs. I am going to TRO with the TREs and am reaming the new/used set from the top-down.
First, does anyone know if the PSG and DVR sides are two diff sizes/heights when it comes to the distance from the bottom of the knuckle to the steering arm? (pretty sure of the obvious answerhere, but would like to know otherwise). see pix.....
Next, do the stock F-150/Bronco knuckles use the same size TREs? Are they close in size to the Chebby TREs? The bottom of the holes seem kinda big.
Finally, if any one has done this upgrade with the Chebby TREs , could you post-up, and have you run into any problems..ie: needing a shim to take up some space in the bottom of the hole.
Thanx,
Sean M
![Angryfire](https://www.norcalbroncos.com/forum/core/images/smilies/angryfire.gif)
Thanx,
Sean M
